2008 22ve Broken Speedometer - easy repair?
    we had a lift installed and the guys put the supports in the wrong spot so I guess the speedo sat right on the bunks and broke off the paddle? I don't know what it looked like before but im assuming just the paddle is broken off
    Wondering how hard of a job this is to do and if it needs to be done from the inside of the boat or from underneath? And what the process is depending. I believe the marina here has the parts but looking to do it ourselves quickly as to not lose any time on the water, thanks.
    The paddle wheel can be replaced with a paddle wheel and axle kit. With the boat on the lift, the tri-ducer assembly is released from the base from the inside so it can be serviced. Maybe a 3 minute job.
      Thanks a lot! Where would I find something like that?
