2012 RZR fuel gauge stuck
    The fuel gauge on my dash and in the gauges screen on tige touch are both stuck.. The dash gauge is the digital with the bars and it indicate full and the gauge and % on the tige touch are showing 98%.
    It was working Friday as I filled up to 98% and has stayed there since. We rode all weekend I added 15 gallons twice and then took to the store on trailer and it took 24 gallons to fill.
    Gauge stuck whole time. Any help?
    #id
    probably need a new sender, or the wire has come loose\ shorted to ground (can remember which way goes to full)
      #id
      Did you fix the stuck fuel gauge? I have the same problem on 18 rzx2. Stuck at 100
