acceleration problem
    i have a 2006 20i. randomly, when you put it in gear and attempt to accelerate it just stays at idle. to correct the problem, i have to turn the ignition off then restart it then it is fine. it probably happens about one in thirty starts. any ideas?
    #id
    That certainly sounds like its in a limp mode. If its a marine power thats throttle by wire, the throttle lever position sensor is a good suspect. Knock sensor is also a common possibility. Probably not much to do until you get it scanned for any stored diagnostic codes.
      #id
      along with chps suggestions check the potentiometer behind the throttle lever $100 black plastic piece that caused me the same issues you are having on my 07 22ve. It was intermittent like stated and will eventually get worse.
        #id
        JLG
        Where did you get the potentiometer from? I am having idle and speed set issues that I believe will turn out to be that part.
        Wake Up or Stay On Shore!
