Tige Speed Set to Perfect pass
    Can you convert a speed Set Control to a Perfect pass? For an 06 Model Tige? Would it be beneficial?
    #id
    Beneficial for sure, if you could. If its an 06 with a Marine Power DBW, then the odds are, no, it cant be converted.
      #id
      ^^Exactly
        #id
        Thanks Mike
          #id
          I'm thinking I'd really like to get an 05 22v
          w/ the MP 380 hp and perfect pass.
            #id
            Why are you looking at the 380hp? 340hp seems to be enough for me at 3k in ballast and 2100 feet elevation.
              #id
              I really don't think you need the 380 for the 22 footer, that'll probably be hard to find anyways. The 340 with an acme 1235 (or comparable) will get you out fine, even if you load it down.
