Engine Problems
    Engine Problems
    Let me first start off by saying i love my Tige and wouldn't trade it for any other boat; I haven't posted anything on here before due to most of my questions i can get answered by reading these threads but, this time I am in need of some assistance. I have a 2003 22v Riders with a 330 PCM motor. For about the last three weekends my boat has been acting very strange. It runs just fine for the first pass or so and then it will start to loose all its power. It will pull me out of the water but will never get up to speed. My driver will try everything from full throttle to the least amount possible to get up to speed. I have been told it may just be the fuel filter but, i am having a problem even finding one of those. It does it with either my perfect pass on or off. It acts like it may be starving the engine of fuel. It has progressively gotten worse. At first it would only do it for a couple of seconds and then it would take right off but, this evening it wouldn't ever take off. I know this may be a long post but, i wanted to be as detailed as possible. If anyone might have some insight as to what the motor might be doing it would be much appreciated. Again i am going to try and get the FCC element replaced as soon as i can find one. One last question would be the PCM manual says there are 2 fuel filters one in the FCC and another primary one before the FCC. If there is another one besides the one inside the FCC it must be buried below the fuel cell, because that is the only place i didn't look.
    #id
    Look at the aft port side of the juel tank, you will see where the fill hose is and just next to it you will see the supply hose going to the engine. Follow that to the FCC, if there is a primary filter it will be in that line.
    Greg Denton
