2001 21V problems???
    new boat to me as of yesterday. Steering wheel is not straight when boat is, pulls hard to right as speed increases, trans oil light is on oil level is ok(where is sensor and how much$), has shower switch..where is the shower supposed to be? Thanks...
    Not sure I can help you with the steering issues, but
    The trans oil light will be on when the boat is at idle. Should go off as you throttle up. If you search the forums there are severval posts on this over the last few years.
    The shower could be anywhere. Depends on who installed it. If you've not found it by now, chances are someone took it out.
      All of the boats have a shower switch but they do not all have showers. The light on the dash is not for the transmission but for low pressure in the v-drive. The light is controlled by a 2lb pressure switch.
