Perfectpass does not work
    I have a new 24V and the perfectpass stopped working. It will turn on and show the speed on the left, but it does not show speed> any suggestions. thanks Mike
    #id
    Check the sensor under the boat. There is probably debris in the paddle wheel that is stopping the wheel from turning.
    Ray Thompson
    2005 22V
      #id
      Perfect pass stopped working
      Thanks. Were is the sensor located? Mike
        #id
        Most of the time, they are on the starboard side, just to the right of the last tracking fin.
          #id
          Paddle wheel
          Just replaced my paddle wheel, its located opposite the raw water intake side, I access it from under the rear seat of my 21v riders ed.
          If you have to replace the paddlewheel, order it direct from PP. It's less than $17 and they ship it right out.
          Love your little ones!
            #id
            Perfect Pass Reset
            I had a similar problem (set speed shows on left, but actual speed reads zero (or very small, inaccurate, number). After changing the paddle wheel, the problem persisted. I finally reset the PerfectPass (version 6.0 - 2000 model) by pressing/holding the "Menu" and "down" buttons while turning the ignition on. From there, the reset process was intuitive and PerfectPass worked great.
            As an aside, I accidentally chose "Digital Pro" instead of "Wakeboard Pro" and that WASN'T intuitive. I'm glad we don't have any skiers that require the options for "Digital Pro"!
            Richard
