How do I adjust the steering?
    Last summer the wife put our 05 22v into a sandbar, crunched it pretty good. The dealer got it all fixed for us and we just took it out, if I hold the steering wheel straight the boat pulls to the right a bit, the boat tracks straight, but i want the wheel straight too...is there an adjustment on it??
    Thanks!!
    #id
    IT's pretty easy to set the wheel. The guys at the factory set the boat up at 30 mph with the boat going straight. Then they back off the throttle while holding the wheel at whatever position it is in. Now you need to crawl under the dash (easier if seat if removed) and locate steering column/mechanism. There are four bolts in a square pattern holding the steering cable to the steering bar (terminology??) loosen those four bolts and pull the steering cable out a little, straighten the steering wheel and re-insert the steering cable to the helm/steering bar and now re-tighten the bolts. This should take mabe 15 minutes max!
