3 of the 4 filler ballast pumps are not working in my boat. But I cannot get at them as they are under the floor hatch. Any ideas how the hatch lifts? I can see the rectangle outline in the carpet.
How do I get in the floor hatch on 2007 rz2
Sounds about right. Sometimes they have some bolts with nuts andwashers thru the sides and these are the tuff ones to get at. Not all of them have them. So hope you got it out.Originally posted by Macledb View PostGot it. 6 screws hidden in the carpeted trim along the base of the center seat "box". Behind it will be 3 large screws.
Yes, the center seat section does need to come out of the boat. There is a bolt/nut on each side that secures the seat box to the boat. If you remove the engine dividers and climb in the locker, you will find them. You will need a 7/16 box end wrench for the nut and a phillips bit in a power driver for the screw head. Once the seat box is out, the floor lifts up from the rear.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
That sucks, cause I have a pump not filling, and the dealer told me to do this on the lake. He said it may be locked up and need to pull the top up then put back on. I can barely reach the pump enough to rotate the top, but not pull up. So not sure how much fun all this will be to do on the lake?
