Heater Install location on 2009 RZ4
    Does anyone have any information on the heater and switch location of the factory heater on a 2009 RZ4? Pictures would be great if you have them.
    #id
    what are you looking to do? i would guess the factory heater location is the compartment infront of the driver in the bow... like on most of them. you doing a new install?
    2011 Tigé RZ4
    www.re-viveupholstery.com
      #id
      That is what I would like to do. I have been looking at the Heater Craft models. I have some ideas from all over the web, but was wanting to see how Tige does it from the factory. Also would like to know where they installed the switch on a 2009. Any help would be greatly appreciated.
        #id
        This is where I put it on an 2008 Z1
          #id
          Thanks for the pics. Where did you put the actual heater? Do you have pics of that install?
            #id
            Thanks for the pics. Where did you put the actual hea youe ics of that install?
            No problem, I put it in the locker ahead of the helm. I can post up some pics tomorrow, but you might do a search on heaters. I've posted it up before and there are some other installs on here also
              #id
              I put the heater in the Helm locker and put in 3 vents, it was a two vent heater and I added a Y splitter. One vent at the driver, One pull out vent out of the side of the Helm locker and one vent under the observers seat.
