I thought that I had winterized my heater well and it was stored in a heated hangar, but this year I have a constant drip coming out of my heater near where the hose attach. It doesn't appear that it is the hoses that are leaking but rather coming from within the heater. Has anybody tried to fix their heater or is the best option to just replace?
Heater is dripping water
I had the same problem,I took to a radiator shop and had it repaired. Cheaper than buying a new oneOriginally posted by Moki View PostI thought that I had winterized my heater well and it was stored in a heated hangar, but this year I have a constant drip coming out of my heater near where the hose attach. It doesn't appear that it is the hoses that are leaking but rather coming from within the heater. Has anybody tried to fix their heater or is the best option to just replace?
Depends on the root cause of each failure. Are they rusting out, are the nipples breaking off or are the cores freezing due to not being fully drained during winterizing? If you are looking to add the valves to stop flow to it, then just pull the nipples from the block and replace them with plugs. This eliminates any possible leaks in a disabled heater system.Originally posted by dozzerdude View Postwe had a shop try to repair ours once. that only lasted a year.I think we are on the 3rd heater craft core now. im thinking of putting hot water shut offs to the heater this time,might help.
Depending on the size of the hose or split, it can be soldered closed. Acid-core solder and a mini torch.Originally posted by Moki View PostThat's a good idea. My problem with my heater leaking is that I have all of my amps in the same compartment.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Unfortunately, the auto parts route only works on the 2 vent systems. I ordered a new core off of this site http://www.jmsonline.net/heater-craf...y-het-h301.htm
