Ok so we were out today and all was good for a while then I started getting 2 beeps every few min. Everything seemed fine oil temp and all were ok. Then I noticed when I shut the motor of the fuel pump stayed running until I turned the battery switch off. Waited a min. then turned switch back on and it was fine and boat started and ran fine but still 2 beeps every few min. But every time I shut the motor off the fuel pump stayed running? Any ideas?
2 beeps and fuel pump stays on??
Did you get a 2 beep alarm when this happened to you? Thanks for the info I hope that's all it is.Originally posted by bobbysky View PostHad the same thing happen to my 02 tige and it was one of the relays on top of the engine. If I thumped it hard with my finger it would turn the fuel pump off. I replaced it with a new one and has been fine ever since.
