I just bought a 2007 rz2 and am trying to make sure everything works properly. When I turn the key forward one click and hit my cruise button, the display changes to speed control but when I press the up arrow to adjust speed up, the numbers on the display stay at 0.0. The only thing I can conclude is that the boat actually has to be running. My friend has a 08 z1 and his will adjust without the motor running. Anyone have any ideas? Thanks
question
This j5d6 guy annoys me.
Actually he's my buddy. Welcome to tigeowners, bud. We are working on his integrated ballast system along with mine. Been a fun winter full of projects on both our boats. We just installed a new stereo system in his boat and drilled his thru hulls yesterday for his ballasts.
That's when we noticed his speedset doesn't set. We went and checked it out on my tige and mine sets without the engine running. Weird.
Welcome to the site and congrats on your boat. Geek should have let you know that you needed to post pics with your first post.
I have never tried setting it without it on. I would test mine for you but the batteries are out. I can check it for you when I put them in if you haven't already found an answer.
First off welcome to the site! Congrats on the new boat! Is the cruise control switch set to on? Guess it would need to be or else pressing the up/down buttons would just change the display between the various settings. I don't think I have ever tried setting the cruise on mine with the engine not running so I don't have a definite answer on that one.
I have the black oval with the arrows on the sides. I would suggest letting your dealer diagnose the problem there are several components wired together to allow the speedset to work properly. It may be something simple.Originally posted by j5d6 View PostThanks a lot for checking. I guess I will get one ordered an put in. Is yours a touchscreen or just the black oval that has speedset in the center and up and down on the sides?? Thanks again.
