My red light located in the center of the dash on my 2002 20v stays on and kind of flickers. I thought this was a neutral light but for some reason it stay on all the time. Does this mean anything is wrong?
Red Light On Dash
It stays on all the time, but my RPM gage is not working so could that cause the problem. Trans fluid seems ok level. Oil level is good. Not running hot.Originally posted by mikehayburn View PostIt should turn off after 1000 rpms.. if it flickers after that..poss fluid low in transmission
That light is connected to a pressure switch on the transmission. When the pressure is low the light should be on (like while at an ideal.)Originally posted by bamaboy2006 View PostMy red light located in the center of the dash on my 2002 20v stays on and kind of flickers. I thought this was a neutral light but for some reason it stay on all the time. Does this mean anything is wrong?Tige, it's a way of life!
Notice your profile says south east china. What part do you live? I have an office in Dongchen District Dongguan.Originally posted by whitlock87 View PostThat light is connected to a pressure switch on the transmission. When the pressure is low the light should be on (like while at an ideal.)
Would low transmition fluid cause the light to stay on?
[QUOTE=bamaboy2006;423130]Notice your profile says south east china. What part do you live? I have an office in Dongchen District Dongguan.
I live in CA, and work in Huizhou city
But i have been helping a vendore in Buji (ShenZen)Last edited by whitlock87; 06-17-2010, 02:22 AM.Tige, it's a way of life!
