Hi All
Just purchased a 2017 z3. Only had it a couple days and we have been loving it. Couple small problems I was hoping you guys could help me out with.
Depth finder and water temp not working. Could this be a software update fix or do you think bad unit? Also Bluetooth not pairing? Software update?
Heat only gets hot when moving. The pump in the back locker does not feel like it is running. Is this in the main fuse panel? Does anyone have the diagram showing what fuse does what?
Boat did not come with the surf link remote. Is it worth ordering one? I can see that it came with one because the holder is still under the dash by the fuse panel.
Thanks in advance for any help!
