2016 r22 with the 6.2 360 when is recommended valve adjustment and ballpark cost?
Valve adjustment
Like engine valves? Id wager that engine uses hydraulic tappets. If so, then no such maintenance procedure would/could be done.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
