Warning! Bilge is Running Alert
    2022 Tige Z3- after last years software update I now get an annoying alert on the screen every time the bilge activates and runs and I have to hit ‘OK’ to get it off the screen. Wouldn’t be such an issue but I can’t count that high how many times I have to hit ‘OK’ during the day so I can see the screen. Last time I brought to dealer for annual maintenance I told them about it they said that they talked to Tige and that they are aware but don’t know how to deactivate this particular nuisance alarm. Has anyone else dealt with this and got this same answer from the dealer? I am so over this situation. Seems like a petty complaint but surely this has been dealt with and rectified by someone in our community. TIA!
    #id
    Make sure it’s on the L configuration of the pump. Your dealer should be able to get you an updated software which should help, some boats are still having issues. Currently in the process of reaching out to tige for a solution.
      #id
      Thank you. I will convey to dealer
        #id
        Confirmed it is in the L configuration and had dealer perform a software update. Warning still appears when bilge runs. Any other suggestions. I am truly disappointed with this situation as makes my lake driving experience less than stellar.
