2017 R20 beeping
    2017 R20 beeping
    Out on water…engine/gas light came on and won’t stop beeping…did restart and service light and non stop beeping continues…?
    #id
    Are all the gauges working? My tach goes in/out and when not working, there is a constant beep from under the helm. When beeping stops, tach is working again.
      #id
      Go to the diagnostics screen and it will show you active and stored faults. Will help narrow down what the issue is.
        #id
        Thanks! I don’t see any corrective action inputs…also above read ‘0 to address’…
          #id
          That will be a bad o2 senser. I believe that code is post cat sensor on the stb side.
            #id
            Ok, I’ll look up 02 sensor
              #id
              Thanks
                #id
                Anyone know if this 02 sensor is easily accessible…don’t see anything like this sensor on/near any visable manifold
                  #id
                  Should be just past the cats. The post cat one shouldn’t need an o2 socket.
                    #id
                    Ok
