Tige' Z3 5.7 PCM 343 HP (2013) Speed / Imtermitted
    Information on Engine: 2013 PCM 5.7 343 HP
    While surfing last week at 10 MPH the boat was on cruse control and then all of a sudden dropped out and stalled, but kicked back in. Did this several times. Docked the boat afterwards and did not get a chance to check out again.
    This week on the lake could not get boat to go over 16 MPH in manual control, and leaped boat back to dock, and finally on the way back it would shut down at times, and while docking the boat would put in reverse the engine would stop and die. Work never go in reverse again and finally at last stuck in forward even thou the throttle shift knob was in neutral position.
    • Stuck in forward gear
    • Put in reverse the engine dies
    • While in surf mode (cruise Control) would intermittent
    Just curious what you guys think or know might be the trouble. Not sure if we are talking a speed control module on the engine or something in the shift throttle device.
    Thanks in advance
