2015 Tige Z1 plug question
    I have had a 2015 Z1 for about a year and I cannot figure out how to do a manual dump of any water that gets into the hull. Obviously I can use the bilge pump but on my previous boats there was a plug or some sort of manual drain I could use....any ideas? I consulted the owner's manual but couldnt figure out if there was one. I have relied on the bilge and a shop vac to do it to date....any help would be greatly appreciated.
    #id
    The older tiges did not have a center plug. Just the one on the transom so you need to be on a slope for it to drain. But with that in mind water should be minimal if nothing is leaking.
      #id
      Whenever I pull out of the ramp I usually will pull the transom plug to drain any water. But yes, only one plug in the transom.
      How much water do you have in your bilge?
