Which sub should I get?
    I have a new-to-me 2017 Z1 and although this boat originally came with a 10” sub, it has been replaced with a 12” Jensen (and everything else is wet sounds). Attached a pic of the amps but I am not sure of their models. I want to a net sun and not sure what to get that would be appropriate for the space and amp. Suggestions?
    #id
    Bottom amp is the Syn-DX2 and drives the tower speakers. Top amp is the Syn-DX6 and drives the cabin speakers on chnls 1-4 and the woofer bridged on 5/6.
    The new woofer will need to be a single 4 ohm voice coil or a 2 ohm dual voice coil. The amp is rated at 600W rms on 5/6 when bridged. However, I believe the amps are the OEM DSP versions and have no on-board consumer level adjustments. Many feel they are tuned very conservatively.
    A specific amp model suggestion is going to depend on how the woofer will be installed. Free-air/infinite-baffle as it would have been from the factory or a small sealed or ported enclosure.
      #id
      Truly a Tige master! The sub will be under the dash. Previous owner widen the sub speaker hole from 10” to 12”.
      Thank you!
