2008 22ve speedset/cruise control problem
    So a couple of weeks ago I mentioned that my boat was going to “limp mode” after about 30 or so minutes of just cruising the lake. I tightened some wire down at the shifter and in the back hatch. I turned off the cruise control toggle before we took it on a test run and it ran perfectly and never set the cruise. This past weekend I set the speedset with cruise control on and it did it again where it wouldn’t go past idle speeds. This indicated to me that it’s something with the speedset/cruise control. Is there a fix for this? If so, can someone help me out here?
