Which Cruise Control?
    I am comtemplating putting in a type of cruise control this winter and was wondering which one you guys recommend. Should I buck up and spend the 1300 on the GPS from Perfect Pass? I want it because it is real hard to find the perfect setting for boarding
    #id
    I have Perfect Pass Stargazer and love it. It maintains your set speed + - 1/10 to 2/10. It has been flawless and is very easy to
    operaterate.
    From what I hear Zero off is great also.
    Formertigeowners.com
      #id
      What boat do you have?
      Most of the time perfect pass is your only option.
      Common Sense is not so Common
        #id
        2001 20i... has the Mercruiser 350 Mag MPI
          #id
          Perfect Pass Stargazer is all you can get.
            #id
            i guess my next question is... how hard is the install? Do I have to drill the hull? Cause that would make me not want to get it.
              #id
              Nope, its GPS, so no paddlewheel. The hardest part is running wires into the engine compartment. Everything else will be swapping out the guages, mounting the box and hooking up the throttle linkage.
                #id
                so for someone who is a newb it might be best to have done by a professional?
                  #id
                  No you should be fine.
                  The directions are detailed and Perfects Pass' customer service is very good.
                    #id
                    Perfect pass
                    Perfect pass' customer support is excellent.
