another taps not working...
    My problem is directly related to the wiring to the gauge in the dash. I installed the Perfect pass and now the light to my analog speedo isn't working and the Taps does nothing. They all worked fine before I messed with the gauge.
    Does anbody know the wiring scheme for the taps gauge. I'm thinking the power wire was jumped to the taps from the speedo I removed...or maybe the ground. I did reconnect all of the wires together that I took off the removed gauge so I thought I should be okay. Nope.
    I knew that damn install of the perfect pass was to easy!!
    Also, what's the "sig" wire that was running into the back of the speedo gauge? That's the only wire left "loose" behind the gauge panel.
    #id
    All the gauges on my dash are daisy chained as far as power and ground.
