2012 Z3 Dash Buttons not working
    The buttons beside the touch screen have quit working. They worked fine one day and then the next they didn't work. The touch screen is working just fine, but once I pick a screen I am stuck there unless I restart the boat. I have looked under the dash for anything glaringly obvious but did not find anything. Any ideas on what to look at next to try and troubleshoot this problem? Thanks!
    #id
    My screen will act up if my battery voltage is low, or I have the battery switch set to one battery only. As long as I keep my batteries healthy, it has no glitches. If not, it becomes unresponsive or sticks on a certain screen, or goes to a different screen vs what I’ve touched. The only way I could fix it was to press the on/off button to restart the Tige Touch.
    I use a dual bank Battery Tender trickle charger with quick connects whenever my boat is not in use. Not only has it improved the life of my batteries, the frustrating screen issues have gone away.
