Two 120 volt plugs for batt charging?
    Just below the battery switch there are two female 120 volt plugin's about 6 inches apart.
    I would assume that one is for charging the batteries, I don't know what the other one is for.
    The lower one when pluged in goes to the dual battery charger. Any ideas?
    They are no factory, so I could not say why there are 2.
    Best advise, locate the harness on their backside, and trace it to its destination and see what its connected to.
      One would have to be a contortionist to get into that area. baybe a mirror and flashlight?
        You can always just start taking the screws out of the HDPE panels to dig in there. Its basically just a few pieces of plastic screwed together around the batteries.
          Two female plugs? Doesn't the female end usually give power and male plugs receive the power? Could these plugs be wired into an inverter? Perhaps there is a blender hidden in there somewhere too. Keep digging.
