17 Z3 touch screen not coming on
    2017 z3 touch screen not coming on. blue button not lighting up. worked fine last time out. boat has power will start fine just no screen voltage reading 13 plus everywhere i can test it.
    #id
    Check for power at the red wire going into the blue button. If no power, check the 15 amp fuse at the fuse panel under the dash.
    If you have power, check your ground at the switch.
    Oh Yeah!
