Battery charger
    Battery charger
    What do y’all recommend for an onboard charger? I want something easy to plug up so that my battery is always ready to go. I had a long paddle home yesterday. Thanks in advance.
    I got a noco. Works great. I put a thru hull plug in a rear locker for easy access for charging.
    Get a bank per battery. Isolator switch should be off when charging.
    NOCO Genius GENM2 8 Amp 2-Bank Waterproof Smart On-Board Battery Charger https://www.amazon.com/dp/B00CBTRMZ4..._V.mWAbCTPXCQW
    Sent from my SM-G950U using Tapatalk
      A marine multi-bank, multi-stage smart charger is the way to go. I like to go with one that delivers an amp output of about 10% of the total battery Ah. A conveniently placed charge outlet, like in the rear locker wall, makes it real easy to plug in your extension cable and close up the boat.
      I like the Promariner prosport series for a medium duty on-board charger. it offers distribute on demand, meaning it can send its rated output to just one bank if demand warrants it.
      http://www.mikesliquidaudio.com/Phot...05/category/61
        I bought a promariner at chp's advice many years ago and it worked great. wired it in above the taps pump and laid the cord in the compartment where the shower was. back into the garage, plug in and voila- charged batteries every outing.
        2012 22ve.. RIP 4/17
        2014 Z3.. Surf away
          I have this one and am very pleased.
            I also have 2 of the NOCOs. I've had the promariner too and prefer the NOCO. Either are great options.
            BABz - babzusa.com
            Austin, TX
