Starter issues on 22 VE
    Replaced starter but still get a click click click sound and it won't turn over engine. Anyone had this experience?
    #id
    What's the voltage at your engine battery?
      #id
      Then compare that to the voltage at the starter.
        #id
        Exactly
          #id
          Have you had the starter battery tested recently? A tired battery might not maintain the voltage necessary to push enough current through the starter to turn it, and the relay will disconnect giving you the clicking sound.
            #id
            Ground is lacking or terminals on either end of the positive or ground cables are dirty.
