I'm installing a dual battery system with the blue sea add a battery switch and ACR. I have a starting battery and 120AH group 31 deep cycle and I'm looking for an on board charger. I wired the ACR on the boat side of the switch so I can get a dual bank charger and charge separately while the switch is off. I've read that you should have an amp rating equal to 10% of the AH rating of the battery which puts me around 10-12 amps. My question is if I'm not worried about speed, is 4 amps per bank acceptable? Is this 10% guideline for the health of the battery, or just in order to get the battery charged overnight? If I need the 10amps I might just get a single bank 10 amp since my starting battery will only be used for starting and the alternater will keep it topped off. Here is the dual bank charger I'm looking at:
https://www.amazon.com/dp/B00CBTRMZ4...GQNYNANU&psc=1
