Tige Touch Light Controls
    I am installing LED speaker rings and a boat plug light on my 2011 RZ4. I want to wire them into the controls on the Tige Touch. I have 2 light switches that are not used, the Under H2O light and the Docking Lights I believe. Does anyone know where the wiring harness is under the dash for the lights? Or, what color the wires will be? Thanks in advance for any help!
    Have you test fit that plug light? Ive come across quite a few instances where they are not fitting boats with wake plates and wedges. Cruz wakeword, MB, TMC and Moomba forums for more info.
    Anywho, your boat is pre-wired, so somewhere across the transom will be wires labeled for transom lights. Same with dock lights, except that harness will be found behind the bow speakers.
    If you want to locate the outputs closer to the helm, grab a volt meter, pull the cover off the viper box and find the appropriate fuse. Double check it with the meter.
    http://www.wakeworld.com/forum/showthread.php?t=806612
    http://www.moomba.com/msgboard/showt...ith-these-guys
    http://www.themalibucrew.com/index.p...lug-led-light/
      Chpthril,
      I have not checked the fitment, yet. I haven't purchased one, but, I bet you are right. My drain plug is right above the wake plate. I haven't thought about tying in close to the fuse box, that's a good idea. Thanks again, man, you definitely know your way around a boat!
        Here's a pic of my LED speaker rings. I have approximately $4 in each speaker.LED.jpg
          Very cool!
          Originally posted by b_jackson_03 View Post
          Here's a pic of my LED speaker rings. I have approximately $4 in each speaker.[ATTACH]43652[/ATTACH]
          Where did you order them from?
            The underwater light will be at the transom tied up with its ground. Should be a blue wire if not blue with black stripe.
            The docking light goes around the bow and for some reason I want to say its blue as well. You are better off putting a wire directly to the channel on the power module (the black box with all the fuses) and run it to your RGB controller.
            Oh Yeah!
