Check my power thinking please
    So I don't have a diagram - so hopefully my description will work out.
    Up to this point, I've just had a simple Kenwood head unit connected to 4 speakers. Time to upgrade a bit, but I'm not going crazy, since I'd rather spend money on boat gas than stereo.
    So - here's the changes/additions:
    1. Replacing Kenwood unit for another so I can have a remote at the helm
    2. Adding a 900W amp (note it has a 40amp fuse on it - hmmm - but I don't think I'll pull that much since I don't play things that loud)
    3. Adding a Clarion CMG2510 10" sub 250W peak, 100W RMS
    4. 4 speakers 180W peak, 60W RMS
    So, I'm starting out with just one battery - perhaps adding a second shortly. I know if I add a second amp/tower speakers, etc, this is pretty much a requirement.
    My current alternator is the stock 55A - first question - should I consider upgrading to a 100+ Amp alternator
    On the wiring side:
    1. I was going to pull a short (12 - 18") 4 GA + side wire from the battery through a 100Amp fuse to a fused distribution block
    2. 50 Amp fuse at the distribution block feeding 8 GA wire from one post of the distribution block to the Amp
    3. 15 Amp fuse at the distribution block feeding 14 GA to the head unit
    Set up a buss bar for common ground - not sure what size cable from the bus bar to the - side on the battery....basically mirrors the + side wiring?
    It will likely have a continuous draw of around 25A
    Im a huge fan of having dual battery banks in a boat, but a 2nd bank for audio is not really needed, until you want to drop anchor and play the tunes. I would consider doing the 2nd battery bank at this time, because your amp wiring will have to be relocated once the dual bank and switch is installed.
    This will give you some room to add a 2nd mild amp later
    Id go with a 30A
    If the ground run will be about the same distance as the B+, then it should be the same size. On that note, I would consider a combo fused/ground 1 in/2 out block as opposed to a fused block and a BUS bar. You can still add that 2nd amp later.
      Mike - thanks for the quick reply - I appreciate the suggestions!
        So assuming I would use a wet sounds WW-BIG Block combo, and it uses ANL Fuses , how do I get a small enough fuse for the head unit - run another inline after the block combo (given that ANL goes down to 35A sizes)?
        or are you suggesting a different combo block?
          You need to draw this out. Will really help if you have the amplifier specs. Each amp has a recommended fuse size in the manual.
            What fused block with a 4ga in/8ga out that holds a 50A and a 15A fuse did you have in mind? I use the Metra T-Spec V12DB14PN. Then use an inline fuse holder an piggyback the end in along with the amp lead. Doesnt take up that 2nd fused outlet just for the head-unit.
              Mike - PM sent
