Trying to figure out how to wire up this ballast switch properly. This is a lighted ballast switch with Fill/off/Drain. For some reason I am not understanding how/why it works the way it does.
- +12v to B and the rocker is in the down position(drain) gives power to A and if the rocker is in the up position(fill) it gives power to C.
Is this correct? What is prong D for? It just worked opposite of how I thought apparently.
Hmmm, must be back feeding through the windings of the pump that not in use.
