need help finding a throttle sensor
    i need to find where i can get a new throttle sensor for a 2007 24 ve the 350 my shops on back order and need one asap
    #id
    Are you talking about the pps on the shifter ? If so it is available from PCM.
      #id
      Hi Dom,
      I have 2008 Z1. Intermittently we shift the boat in to gear and there is no throttle response. Shut off ign and will be fine for a while then back to same thing. Would this indicate it is the throttle position sensor that is failing. Do you know where they can be purchased only and how much vs purchsing whole throttle assembly. Have you been thru this already.
      Thanx
        #id
        There is another post on here already that has a source and part number for the sensor.
          #id
          would you have any idea how to find this post. Does the new TPS have be flashed by a dealer to work
            #id
            No, it's just a sensor, but it does need to be adjusted. This can be done with either a volt/ohm meter if a scan-tool interface is not available.
              #id
              can you help me find the post. I am in Arizona this week and want to pick up
