Accessory Rocker Switch - 2005 24V
    Does anyone know what the Accessory Rocker Switch does on the 2005 24V? It lights up when I toggle it, but doesn't seem to do anything.
    Does anyone have a .pdf of the 2005 Owners Manual that they may be able to share with me?
    Thanks!
    brose
    #id
    Could have been for a transom light.
      #id
      Did Tige ever install anything on the ACC switch or is it always just for aftermarket installs?
      brose
        #id
        Unlike a car the t would just put a blank cover where a switch could be; Tige’s have all available switches.
        The accessory switches are ones that did not get wired at the factory. (At least in my case)
        Tige, it's a way of life!
          #id
          I have a accessory switch on my 01 21V that doesn't do anything. I pulled the switches out looked at the wired color code and if I remember right it was brown/yellow. I then went to my fuse panel and saw it back there attached to where a heater would be wired I think.
          I am going to unattached the wire at the switch and run a wire to my stereo.
          15 Escalade ESV-Black
          08 RZ2-Blue
            #id
            My accesory switch is wired with power but has nothing powered by the switch. I have added nothing yet that needs the power. Maybe use it when I install the transom lights
            Let it be!!!
