Hey guys, hope someone can help me here. 2007 22Ve, 5.7l.
When I turn the ignition to "on", the lights to the gauges come on, but the info from the gauges does not show. No alarm buzzer, no fuel pump priming, and no effect from the new starter when I turn the key to start position. Bilge pump, radio, running lights all work. AI says it is probably a problem with a red wire going from the starter to the ECM, but I do not have such (that I am able to track through all the flex loom stuff anyway). Can someone suggest a a bypass or the like that I can test? Or let me know which pin on the ECM harness to check for power? Thanks for any help!
Ritchie
Ritchie
