2019 R23 subwoofer issues.
    It started as an intermittent issue, I would get power to the sub in and out for a few trips, and then one day nothing. I took the sub out of the box under the helm to see if simply a speaker wire had come lose. But, they were both connected very well and didnt see an issue there. I even put a different subwoofer in to see if the sub itself had failed. No sound came out of the test subwoofer either. Mind you both wetsound amps have power and all of the rest of the system works great including the tower speakers. I assume it is a disconnect somewhere in the hull but I am having trouble tracing the sub wire back to the amp itself. I did inspect the connections at the amp that powers the sub and looked good at that point.
    Has anyone else had a similar issue and knows of a quick point to diagnose, or is there a wiring diagram somewhere out there on the inter-webs that someone may have seen? Any help is much appreciated because trying to jam out with zero bass kind of stinks. This is irritating.
