Gauges Bouncing Up and Down
    Hello everyone, hope all is well. Wanted to check in if anyone has experienced this issue before. When engaging the taps button on the throttle, the gauges start to bounce every click. Gauges Bouncing: Fuel, Volt, Temp, Oil I am confused at this point. Everything is tight on the gauge bolts and made sure that contacts haven’t rusted already.
    #id
    Is the battery fully charged? If it’s a Lenco actuator, taps takes a pretty healthy slug of current when in motion…can cause a voltage sag if battery is weak.
