Indmar starter solenoid?
    Do these Indmar engines have a starter solenoid? Sometimes I am getting a no start then give it a second it will start. The starter was new last year. So either my ignition switch is on the out or the solenoid. Guess if I dug around I could find it.
    #id
    Well it did would not start Sunday one time. Of course I was drifting into another boat. Wednesday evening we went out it started off the trailer tied to the dock, parked the truck then no start again. No problems whatsoever after. I am out today and no issues so guess I’m keeping an eye on this. If it’s a neutral safety maybe I can adjust.
      #id
      Were you able to figure out what the source of the problem was? I am having the same issue with my boat. I have replaced the started and the ignition. It starts right up when cold and then later will not start or takes a few tries to start. It has to be something electrical because it will not even try to turn the motor over.
      Any help would be greatly appreciated!
