ballast pump stays on
    i have 2010 tige rz2 i just changed my rear port side ballast pump and it’s stuck on i have to remove the fuse to turn it off what would be causing this
    #id
    Maybe a stuck relay contact… try to swap relays with a different pump and see if the other pump stays on. If your boat doesn’t use relays, it could also be a stuck switch contact…
