Rbg lighting
    Rbg lighting
    Wondering if anyone else has this problem.
    all my lights work great except one of the tower blade light. It works but runs a different color than the rest. It’s as if one of the wires isn’t working. 2020 Zx
    #id
    The solder at the base of the RGB strip probably broke.
      #id
      Rad. I’ll give that a look. Thanks.
        #id
        If the entire strip acts the same, then issue is as the base of the strip or up stream. If part of the strip works normal and part does not, it needs a new strip.
        try cycling through the 3 primary colors; red green and blue. If one color does not light at all, then as noted above, the solder likely failed or there is another open in the circuit at the last point there is a splice/connector. If 2 of the 3 are their correct color but the 3 lights but is not its true primary color, then the strip is bleeding over between 2 colors. This is usually an issue at the end of the strip where the wires attach. Likely easier to just replace the strip rather then try to resolve.
          #id
          Found the problem. One of the blue wires was smashed and broken. Extended and soldered.
          thanks for the help.
            #id
            Suhweeeet!!
