Battery Cable?
    Battery Cable?
    I am getting ready to start my dual battery project. I see many posts that say they use 2/0 cable. Is this what everyone uses? Where is the cheapest place to get it? Also if I have a flooded battery is that what I have to add, or can I use a Gel?
    The size of the cable depends on what load it will carry and what length the cables will be. If you intend to use the 2nd battery as a starting back-up battery, then 2/0 is probably right. If it's just going to be for the stereo and will carry no more load then what the alt puts out, then 4 ga may be just fine.
    So far, the cheapest place to get cable by the ft is knukonceptz.com.
    I'm not a fan of mixing battery types as they charge at different rates. You can end up with under/over-charged batteries. How are you planning on wiring it up, are you going to use an isolator?
      I was planning on the blue sea add a battery. Should I use the switch in the kit or get the 1/2/on/off?
        I have bought battery cables from a eBay store called genuinedealz. Pretty good $$ and tinned wire.
