3 amps. memphis 1000d, jl 6450, alpine pdx4.150. wet sounds 3 some, xxx-xs sub, ws420, 3 pairs of wetsounds xs 650s,
i have two interstate batteries, one cranking and another deep cycle.
my first question is how long can i play my radio all out with the key in acc until im dead on the water..
my next question is that i also have 2 brand new orbital gel filled batteries that are marine sitting here. can i add both of them and will my alt. be able to handle them or al least one.
Not to mention you have two different types of batteries going on here.
The batteries for the stereo will certainly be better then one Deepcycle, but I would recommend NOT adding the 2 orbitals to the one deepcycle in current use. Remove the deepcycle and use the 2 Gel's. If they do not give you enough play time, then add another. It's never a good idea to mix different battery types (wet cell lead-acid and Gel's or AGM's) on a single bank as they will not charge at the same rate. The alt will over charge one under charge the other. Even though, when 2 or more batteries are wired together, they will equalize, it's still not best for the entire system. So, go will all one type of battery for the stereo bank. Does you 06V have an Isolator? Not sure when Tige started using them. If not, you need one. If it's a Diode type (used from the factory, you may want to consider swapping it out for an ACR (auto combiner relay) like from Blue Sea. The diode type can have up to a .7 volt drop across the diodes and on a typical system, this will not be a problem (never was on mine) but on yours, it could result in less play time. But, if you use an on-board charger/tender to top off the batteries at night at the dock or home, this would be a moot point as the charge will bypassing the diode Iso.
I still have a hard time thinking its OK to blast one's music all over the lake for an extended period from a fixed location; but that's just me.
