I have a 2005 24v and have lost the power to the stereo power amp. Only my front speakers work and I checked the power at the amp and there was not power. Is there an inline fuse somewhere
POWER AMP - LOST POWER
Depends on the installer, was it factory, dealer, or dealer sub'd? Hopefully there is a fuse or circuit breaker near the battery.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
There may be more then one breaker ( for other components)Originally posted by mjohnson37 View PostIt was a factor installed. The breaker near the batter is OK. That is why I thought it was an in-line.
X2!Originally posted by philwsailz View PostWeird...
What amp is it and when you say you checked the power at the amp, what exactly did you do?Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Supreme Tigé Master
- Apr 2007
- 12007
- Lake Carl Blackwell, Stilly, USA
- 54 Bellcraft, 56 Burchcraft, 61 LoneStar, 75 Catalina 27
I thknk in 05 you had a choice of Kicker or Clarion amps.
You measured the voltage with a volt-meter, right? If you got nothing the issue is somewhere in your power wiring, and that has a chance to be dangerous if there is a loose wire. You might disconnect the negative wires from your battery, and then start to trace the positive power wire to see what is up.
Or the breaker or fuse really is bad, but does not look like it?
I am guessing, but want to help you for sure!It's not an optical illusion.
It just looks like one.....
on my 05 it is a Clarion Amp. Either the apx 400.4 or 480.4. The sub is bridged to 2 channels and the rears are on the other 2 channels. The fronts run off the HU. The power wire to the amp has an inline fuse. It will be in the port side rear v drive compartment. If it was wired like mine the power wire comes off a lug attached to the transom. Minw was on an 8 guage power wireLet it be!!!
