sub location with ballast system
    where am i gonna mount my subs in my boat if i have hard tanks in the storage compartments. i have a 2006 tige 22v. wanna go with either a solo baric l7 15 or then new wetsounds big boy ported.. any ideas please. thanks
    will
    I have mine under the dash and under the glove box
      any pictures?
        i have a polk 12 underdrivers side on top of ballast if you look you cant see the woofer untill you get down and look and i have another 12 in back storage on top of ballast.
          Originally posted by kana12 View Post
          any pictures?
          I can put some up tomorrow
            will
            Unscrew the ballast tank and slide toward the front of the boat, install the sub the remount the tank to the floor with some longer straps.
              ^^^^ I had do a similar thing to the ballast tank on the drivers side storage console when i installed the sub in a 20V. That is a tight spot to work.
                any pictures? any one have a ported setup?
