Light Bar Install?
    Light Bar Install?
    I know it's not speaker related, but I figured it is more suited to this forum then anywhere else.
    I have my tower speakers pulled off the tower to get repainted and I want to run power for tower lights. I don't have the lights yet, but while the tower is in sections it would be smart to run the power now.
    Say I want to do a 5 light setup with front and back lights what should I run?
    "the plural of boo is booze."
    If you go with LED, you could run 2 pairs (1 for the front lights, 1 for the rear lights) of 18 or 16 ga
    If you go with Halogen, Krypton etc type bulbs you might be ok with just 2 pairs of wire if you you stepped up to 12ga and used relays to ease the load on the switches.
      what he said
      http://www.wakeboatworld.com
      []) [] []V[] [])
        Got any links of LED light setups? I've only seen the automotive style foglamp Halogens.
          http://www.wakeside.com/page/w/CTGY/...d_tower_lights
          you could also check ebay
          http://www.newdimensiontowers.com/home.html
          The sun never sets on a badass
            Originally posted by wannabewakeboarder View Post
            Wannabe, which light bars on those to sites are LED's, I could not find any listed as LED in thier description
              IMO i can't see LED lights on a tower being useful for anything. Yeah they can be bright but only for a very short distance. I'm putting two 5" round 55watt lights forward for docking / loading lights and a small light facing rear for usefull light in the boat/transom area. Definately run relays if using 55w or better or you'll fry the wires or the switch.
                I did a google and didn't come up w/anything yet. Maybe knowbody makes LED tower lights I've got a 3 LED backpack headlamp that runs of 2 AA and shots a beam about 7 feet. The RZ docking lights are a pod of about 12 LED's, they are bright but have not seen them at night though.
                  That's kind of what I figured when I heard the LED suggestion. PIAA makes some LED foglamps but not sure how well they would perform. I think LEDs could work in a projection lense. There are TVs that will have their backlight provided by LED and the LS600h will have LED headlights.
                    Pelican and Underwater Kinetics both make LED Dive lights. I doubt they would work for a tower, but might give you a lead at least. They are all DC powered (obviously) and have the added benefit of being water proof.
                      Or there is this:
                      http://www.theledlight.com/dcbulbs.html
