Yeah, he's "spot on". That's probably the easiest method to adjust the tower and cabin levels, without buying line wipers.
Clarion XMD3 outputs
I couldn't find a picture with all three outputs. there must be different revs on the HU. Your's being a newer one.Originally posted by chpthril View PostDoes this help?
From my Clarion XMD3:
Gray (red) front right
Gray (white) front left
black (red) rear right
black (white) rear left
red (red) aux input right
red (white) aux input left
purple (red) non fader right
purple (white) non fader left
I think the NON FADER is the base output?
best photo I found; only has the input (red) and the outputs (gray and black).
http://www.wakeboatworld.com
[]) [] []V[] [])
That was the plan, but with two amps.Originally posted by mtnsmith View PostMy head unit only has to outputs, not three. That is the reason I daisy chained the sub off of the cabin amp so I could turn those down by fading to the rear and have the tower speakers loud. Are you still planning to use any of the high power speaker connections from the head unit still?
I did find the wiring diagram on Clarions site for the CMD4. Looks similiar to your picture.Originally posted by spharis View PostI couldn't find a picture with all three outputs. there must be different revs on the HU. Your's being a newer one.
Across the back of that left to right:Originally posted by TigeDuner View PostI did find the wiring diagram on Clarions site for the CMD4. Looks similiar to your picture.
Antenna -> Clarion's controller input (for changers etc) -> wiring harness(contains power, channel leads, remote turn on, antenna, etc, etc) -> top:inputs and outputs (red (input), gray&black(front&rear), bottom: the solid black cable is probably an input for a wired remote.http://www.wakeboatworld.com
[]) [] []V[] [])
How, then would you suggest I connect my speakers? I have 2 four channel amps. All of my info is on the battery thread that I posted. I can then forward any ideas to the Tige dealer. I also have an existing small 2 channel clarion amp in the boat now that powers the 6 cabin speakers that could be utilized. Thanks
