Amp wall thickness
    Amp wall thickness
    On the 08 z1 does anyone know exactly how thick the amp mounting wall is.. I don’t want to go through the wall and into the walkway but I have a pretty heavy amp rack. I want to make sure I have enough bite on the screws.
    Pretty sure Tige used 1/2” hdpe for the amp wall. You can always pull a small section of the carpet out to see.
      So I can see how thick it is as all of my carpet is removed. My question I guess should have said how deep of a screw can I use. I know there is space between the HDPE and the walkway.
