Help with system
    Help with system
    Just bought a used boat. 2009 Tige RZ2. I think I am the 5th owner. I am about to embark on a stereo upgrade. It appears the boat has seen at least one visit to Hydrotunes or other audio shops early on in its life
    Current setup:
    Old style Non-bluetooth Clarion deck with 2 gauge style remotes
    Four WS Pro 60/80 tower speakers
    Five in-boat WS 6.5” speakers
    One 15” ArcAudio Subwoofer 750W rms / 1500W max (no sound)
    One WS Syn2 amp
    One WS Syn6 amp
    WS420 eq with Mic
    Recent history-
    Some audio guy looked at boat to iron out a few things and told me he thought the amp had a bad channel. Figured I would need replacement/upgrade which explains why the sub is not working
    I keep hitting my head on the inner tower speakers so they have to go!
    This is my Proposed setup
    two Icon 8s (or similar) on the outermost tower mounts
    Sub functioning with the In-boats
    bluetooth capability
    What would you recommend?
    2009 RZ2, factory ballast, 260 hours
    Do you need tuner, USB or wired remotes? If not, add a Wet Sounds blue tooth the 420
    The Syn-DX6 would be as close to a direct replacement for the Syn-6 as there is. This presumes the woofer is good and its a 4 ohm (dual 2 ohm) coil. Now, if you want bump things up a little. Go with Syn-DX4 for the in-boats, Syn-DX2.3HP for the woofer.
    The existing Syn-2 is perfect for a pair of Icon-8.
      I will have to pull the sub to find the specs. I’ll ohms test it - not sure if there is a better way to figure out if it is still good.
      Wetsounds eQ with BT could work. I don’t need USB but I would like controllable BT from the transom...
      Is there a good way to test the channels on the amps? Pretty sure one of them is not right
      Current setup:
      One WS Syn2 amp
      One WS Syn6 amp
      WS420 eq with Mic
      Recent history-
        An ohm check is a good start. You can also move the cone in and out to feel how easy it moves and if there is any mechanical noise.
        For transom control, you would either need the phone back with you, or a traditional head unit and wired remotes. Down side, any new head unit will require new remote(s) and cables, if there are any now.
        Voltage can be measured with a meter. You can also do a few things to eliminate an RCA, etc issues. If the woofer seems good, the wire circuit to it is good, RCA's are eliminated, its likely an amp. Totally plausible to be an amp.
          Try swapping the two wires that go to the subwoofer at the amp to another channel on the amp that works. If the subwoofer works you'll know that the wiring to the sub and the sub are good. Also try swapping around the RCA's at the amp, might have a bad RCA feeding channel 5&6
