Rev8 & 10 RGB LED- where to buy?
    Good morning, im after a set of RGB LED light rings for my rev8 & 10's on the tower.
    Wetsounds has had the rev10 on back order for a year now. Any suggestions on where to buy them.
    I got mine on amazon, do you already have the RGB controller?
      Have you checked with your local Wet Sounds dealer(s)? next, try their authorized internet dealer starting with Odin Earmark Marine in TX. I would also inquire with Wet Sounds and see if they can tell you whether its the ring or the strip which is the reason for the delay. If its the rings, maybe you could find them with the blue strips, source a roll of RGB and build your own strips if needed.
